This is not a support forum for Community Builder or its related products. For Community Builder support you should visit Joomlapolis .
The information given in this category is intended to guide users who want to use Community Builder with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of Community Builder.
Question Issues with the comment delete.
4 years 5 months ago #223347 by SMC
I have issues with deleted users comments being assigned to a current member on the platform.
What would it take to assign deleted users comments to a "former member" profile?
Thank You.
4 years 5 months ago #223354 by rich
User synchronization does not help?
4 years 5 months ago #223383 by SMC
Replied by SMC on topic Issues with the comment delete.
No. If you can share other help then it will be good. Or if you want then I can share the site details.
4 years 5 months ago #223389 by xillibit
Can-you put here please your Kunena report configuration ?
4 years 5 months ago #223394 by SMC
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 200M
Joomla default template details : syndication | author: Cindy Moore | version: 1.0 | creationdate: 9/26/2016
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.0 | creationdate: 2017-01-05
Kunena template params:
Kunena version detailed: Kunena 5.2.6 | 2021-07-25 [ Melia ]
Plugins: None
4 years 5 months ago #223415 by Leen
I see that kunena is not quite the latest version. also blue eagle doesn't really seem like the last version
I think it's better to try your Update the website first
So also Joomla and all extensions to update properly. by administrator>update sites check all and rebuild button click.
then let it search for new updates again sometimes really helps to find all the latest changes.
Also your joomla template seems quite old so try different with a standard Joomla template Protostar or Beez3
With kind regards
Leen
Time to create page: 0.155 seconds
