This is not a support forum for JomSocial or its related products. For JomSocial support you should visit JomSocial .
The information given in this category is intended to guide users who want to use JomSocial with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of JomSocial.
Question System - Kunena Forum plugin causing conflict
13 years 2 months ago #147839 by theronin
The System - Kunena Forum plugin is conflicting with a JomSocial javascript that renders a accept group button inoperable. I disabled the plugin and everything seems to run fine but I see this error in the user Edit Profile screen:
ERROR: plg_jomsocial_kunenagroups: Kunena 2.0 (or later) is not installed on your system!!!
Any ideas how to approach this?
13 years 2 months ago #147842 by xillibit
Can-you put here your Kunena report configuration settings ?
13 years 2 months ago - 13 years 2 months ago #147846 by theronin
Here it is xillibit. Note this is with the System - Kunena Forum pluigin disabled ...
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 160M | Max file upload: 50M
Joomla default template details : uneedo_j25 | author: arrowthemes | version: 1.1.0 | creationdate: August 2012
Kunena default template details : Uneedo | author: arrowthemes | version: 3.0.0 | creationdate: 2013-06-11
Third-party components: Jomsocial 2.8.4.2
Plugins: JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Last edit: 13 years 2 months ago by sozzled. Reason: Reveal configuration report in post
13 years 2 months ago #147847 by theronin
Some additional information. I am running:
Joomla 2.5.14
JomSocila 2.8.4.2
Kunena 2.0.4
Uneedo theme 2.0.4
The way I honed in on the System - Kunena Forum plugin was by disabling and enabling each plugin one at a time and checking to see if the JomSocial accept group button would work. It did not work only with this plugin.
13 years 2 months ago #147870 by xillibit
Do you have thought to upgrade to Kunena 3.0.2 ?
13 years 2 months ago #148211 by theronin
I tried upgrading to 3.0.2 on a backup site and re-enabled the plugin and the issue shows up again.
Any advice would be greatly appreciated.
