This is not a support forum for JomSocial or its related products. For JomSocial support you should visit JomSocial .
The information given in this category is intended to guide users who want to use JomSocial with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of JomSocial.
Merged JomSocial 3.0 Activity Stream problems
13 years 3 months ago - 13 years 3 months ago #147169 by stumpy_dan
Hi I use Jomsocial 3.0 (just upgraded) and forum posts no longer show in the activity stream? Any ideas?
my website
Last edit: 13 years 3 months ago by stumpy_dan.
13 years 3 months ago #147173 by Jiminimonka
Contact JomSocial for support regarding Jomsocial 3.0 integration, they are responsible for handling those plugins now.
Please read the FAQ.
Only one question per topic.
13 years 2 months ago #148511 by RWL
Here is what I posted on the Jomsocial Forum :
I have a problem on the Activity Stream : when a user post a photo or a video on the Kunena Forum, the photo and the videos are replaced by a code.
For example, when a user post a video, it is showing :
And when a user post a photo, it is showing : [Fichier attaché : h5c986de.jpg] How can I show the videos and the photos instead of the code ? Thank you[video]
And here is the answer I received :
For the integration between JomSocial and Kunena, we do not handle the code on new kunena post, we just provide API function that allow to add a new stream. So the missing you mention might be caused by the integration from Kunena to JomSocial, the input parameters which is used when calling our stream API function are not passed correct. You might need to ask for the support from Kunena community for this kind of issue.
Thanks.
So my question is : who can help me ? Kunena or Jomsocial ?
13 years 2 months ago #148512 by Jiminimonka
It depends on which version of Jomsocial you are using, which your post does not provide. Please reply with your Kunena Configuration Report.
13 years 2 months ago #148515 by RWL
I'm using Jomsocial 3.0.3
Here is my Kunena Configuration Report :
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : yoo_solar | author: YOOtheme | version: 1.0.1 | creationdate: Unknown
Kunena default template details : Example Template | author: Kunena Team | version: 1.7.2 | creationdate: 2012-01-31
Third-party components: Jomsocial 3.0.3
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
Time to create page: 0.169 seconds
