This is not a support forum for JomSocial or its related products. For JomSocial support you should visit JomSocial .
The information given in this category is intended to guide users who want to use JomSocial with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of JomSocial.
Solved How to use JomSocial profiles in K 3.0?
13 years 4 months ago #144252 by LjuSha
I am using Kunena 3.0 on my website, Kunena is integrated with JomSocial.
But there is a problem:
When you go on my forum www.srednje-skole.com/forum and whem you try to click on any user to see his profile it isnt linked with his profile on JomSocial, it links it on jomsocial page/profile..
Can you tell me how to fix that?
All options are enabled in Kunena for JomSocial.
Thanks.
Best regards,
Ljubisa Pavlovic
13 years 4 months ago #144263 by Shimei
I have the same issue, and that's what made me begin another thread: Jomsocial integration
I also went to Jomsocial, and was told by Jomsocial staff that the plugin works correctly on their local machine. This is the kind of support I have received since purchasing Jomsocial. So you see there isn't a problem. It's in both your and my imaginations. :woohoo:
13 years 4 months ago - 13 years 4 months ago #144320 by xamire
in /plugins/kunena/community/profile.php starting on line 27
Change this
public function getProfileURL($userid, $task='', $xhtml = true) {
$do = $task ? '&task='.$task : '';
return CRoute::_('index.php?option=com_community&view=profile'.$do, $xhtml);
to this
return CRoute::_('index.php?option=com_community&view=profile&userid='.$userid, $xhtml);
Last edit: 13 years 4 months ago by xamire.
The following user(s) said Thank You: ZeroKewl, dimeoscuro, ArrO, Shimei, LjuSha
13 years 4 months ago #144345 by LjuSha
xamire wrote: in /plugins/kunena/community/profile.php starting on line 27
Change this
to this
Great! It helped. Thanks.
13 years 4 months ago #144711 by Bosse
Didn't help me. Anywhere else I should change the code?
Change this
to this
13 years 3 months ago #145533 by dimeoscuro
Change this
to this
I can not explain how happy I am with this solution .... thank you!!!!!!!!
Time to create page: 0.226 seconds
