This is not a support forum for JomSocial or its related products. For JomSocial support you should visit JomSocial .
The information given in this category is intended to guide users who want to use JomSocial with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of JomSocial.
Question Forum link on Jomsocial not working
13 years 9 months ago #141183 by picturemeclubbing
I just recently did an upgrade with Kunena and all it's components. I also made sure plugins were enabled. But for some reason, even though the menu in Jomsocial shows Forum, it does not connect to it. It redirects me to my profile page. Any ideas whats causing this? :dry:
13 years 9 months ago #141195 by picturemeclubbing
Psst....anyone?
13 years 8 months ago #141202 by coder4life
Hello picturemeclubbing,
From you mention of Jomsocial Menu link I would recommend you ask Jomsocial support for this specific issue. This is external from Kunena menu system and we do not have the correct knowledge to be able to effectively answer this specific issue.
13 years 8 months ago #141639 by picturemeclubbing
so the Kunena Menu Plug-in for JomSocial is not something you guys develop?
13 years 8 months ago - 13 years 8 months ago #141646 by sozzled
picturemeclubbing wrote: I just recently did an upgrade with Kunena and all it's components. I also made sure plugins were enabled. But for some reason, even though the menu in Jomsocial shows Forum, it does not connect to it. It redirects me to my profile page. Any ideas whats causing this? :dry:
At the outset, I do not know anything about JomSocial or how to make it work with Kunena. Putting this aside, it would help better to explain what you mean by "recently did an upgrade with Kunena" and "made sure plugins were enabled". The best way to do this is to post your Kunena configuration report.
The second matter, in relation to the Kunena Menu Plug-in for JomSocial extension is that, yes, this was developed by the Kunena team. As far as we know this extension works (or worked the last time it was tested) but I do not know if this may be the case with recent developments in JomSocial.
On the other hand, the problem you are having may not have anything to do with JomSocial at all. Your configuration report may offer some clues.
Last edit: 13 years 8 months ago by sozzled.
13 years 8 months ago #141797 by picturemeclubbing
I was just stating that I just did an update with all the current fixings.
Here is the report. I hope this can help:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : yoo_revista | author: YOOtheme | version: 1.0.4 | creationdate: July 2012
Third-party components: Jomsocial 2.8
Third-party SEF components: sh404sef 4.0.2-rc.1544
Plugins: Search - Kunena Search 2.0.4 | JomSocial - My Kunena Forum Menu 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.4
Modules: Kunena Latest 2.0.4
Time to create page: 0.151 seconds
