Sticky [Readme] How to translate and update my language into Kunena distribution
15 years 1 month ago #102566
by svanschu
True, but I mainly mean the lang codes on transifex. I need to map them anyway on export, because TX uses _ and Joomla uses - ^^
And most people create with xx and the language is in TX with xx_XX so the language is in TX twice and I have to delete one by hand (it's also a not very nice feature from TX I hope they will add an option to disable that auto creation ...)
But thx for the hint on three digit codes
Kunena Contributor & Language Coordinator
Kunena Birthday Module | Kunena LaTeX Plugin | SchuWeb Sitemap with free Kunena Plugin
Always up to date with Twitter
Replied by svanschu on topic Re: [Readme] How to translate and update my language into Kunena distribution
14 years 7 months ago #118079
by svanschu
Transifex was/is a new service we decided to use to make it easier for translators.
Each new software is not perfect so there where some problems with Transifex and that's why I wrote those posts.
Now it still have some special behaviors which need to be fixed, but the most is running smoothly. Just dive into it and you will see that it makes it much easier for translators.
12 years 3 weeks ago #158746
by komir
Replied by komir on topic [Readme] How to translate and update my language into Kunena distribution
Hi, there is no Croatian translation
12 years 3 weeks ago #158823
by Mortti
Replied by Mortti on topic [Readme] How to translate and update my language into Kunena distribution
--> www.transifex.com/projects/p/Kunena/language/hr_HR/komir wrote: Hi, there is no Croatian translation
Time to create page: 0.300 seconds
