Question K 2.0.3 mk-MK language pack installation problems
13 years 10 months ago - 13 years 10 months ago #139378 by maxadsl
Joomla version 2.5.8
Kunena version v2.0.3 - 2012-11-24
I download Kunena Language Package v2.0.3, extract to desktop and i try to install only 'languages/com_kunena_mk-MK_v2.0.3.zip' file with Extension Manager in Joomla. I get this error
JInstaller: :Install: File does not exist /home/website/public_html/tmp/install_50f55d8512b46/admin/lv-LV.plg_quickicon_kunena.sys.ini
Last edit: 13 years 10 months ago by maxadsl.
The topic has been locked.
13 years 10 months ago #139379 by Mortti
There is a mistake in mk-MK XML file...
Can you fix it yourself?
13 years 10 months ago #139380 by maxadsl
i dont know how to fix it,
com_kunena_mk-MK.xml code
<?xml version="1.0" encoding="utf-8"?> <!DOCTYPE extension> <extension type="file" version="2.5" method="upgrade"> <name>Kunena Language - Macedonian (Macedonia)</name> <version>2.0.3</version> <creationDate>2012-11-24</creationDate> <build>@kunenaversionbuild@</build> <author>Kunena Team</author> <authorEmail>[email protected]</authorEmail> <authorUrl>https://www.transifex.net/projects/p/Kunena/team/mk_MK/</authorUrl> <copyright>(C) 2008 - 2012 Kunena Team. All rights reserved.</copyright> <license>GNU/GPL</license> <description>Macedonian (Macedonia) language file for Kunena Forum Component</description> <fileset> <files folder="admin" target="administrator/language/mk-MK"> <filename>mk-MK.com_kunena.controllers.ini</filename> <filename>mk-MK.com_kunena.ini</filename> <filename>mk-MK.com_kunena.libraries.ini</filename> <filename>mk-MK.com_kunena.models.ini</filename> <filename>mk-MK.com_kunena.sys.ini</filename> <filename>mk-MK.com_kunena.views.ini</filename> <filename>mk-MK.plg_kunena_alphauserpoints.sys.ini</filename> <filename>mk-MK.plg_kunena_community.sys.ini</filename> <filename>mk-MK.plg_kunena_comprofiler.sys.ini</filename> <filename>mk-MK.plg_kunena_gravatar.sys.ini</filename> <filename>mk-MK.plg_kunena_joomla.sys.ini</filename> <filename>mk-MK.plg_kunena_kunena.sys.ini</filename> <filename>mk-MK.plg_kunena_uddeim.sys.ini</filename> <filename>lv-LV.plg_quickicon_kunena.sys.ini</filename> <filename>mk-MK.plg_system_kunena.sys.ini</filename> </files> <files folder="site" target="language/mk-MK"> <filename>mk-MK.com_kunena.controllers.ini</filename> <filename>mk-MK.com_kunena.ini</filename> <filename>mk-MK.com_kunena.models.ini</filename> <filename>mk-MK.com_kunena.templates.ini</filename> <filename>mk-MK.com_kunena.tpl_blue_eagle.ini</filename> <filename>mk-MK.com_kunena.tpl_mirage.ini</filename> <filename>mk-MK.com_kunena.views.ini</filename> </files> </fileset> </extension>
13 years 10 months ago - 13 years 10 months ago #139381 by Mortti
Try this...
(deleted file)
Last edit: 13 years 10 months ago by Mortti.
The following user(s) said Thank You: maxadsl
13 years 10 months ago #139382 by maxadsl
its work, thanks :)
13 years 10 months ago - 13 years 10 months ago #139734 by Mortti
Remember update Kunena to 2.0.4 and it's language files... that little bug should be now fixed in your language. Just run pkg_kunena_languages_v2.0.4_2013-01-18.zip package in your Joomla! extension manager.
All J! 2.5.8 Core languages which someone have made Kunena language files... installing smoothly now, I think...
screencast.com/t/PeOBXYFjfMoi
Time to create page: 0.147 seconds
