Question i have integrate the forum but some changes occur please help
17 years 9 months ago #6607 by mega0079
first of all thanks for reading
jommla 1.5.9
kunena 1.0.8
kunena templete default_ex
templete of joomla jamesolite
well as you can see on my website wwwdotpc-gsdotcom everything looks in order, i mean the menu in the left side, but if you click were it said "foros de soporte" you will find that my menu module is now on the bottom, i want it to be on the left side as the home page show it.
I tried move some css code, but nothing work, is there someone who can help me?
thanks a lot :D
17 years 9 months ago - 17 years 9 months ago #6618 by core2
This sounds like a css problem with your joomla template. Does your template have a fixed width? Can you increase it? Have you tested with other joomla template?
Visit the Kunena documantation .
Last edit: 17 years 9 months ago by core2.
17 years 9 months ago - 17 years 9 months ago #6630 by mega0079
thanks fot your answer, well i havnt try it with another theme, im going to try it, this is my css file
thanks for the help :D
Last edit: 17 years 9 months ago by mega0079.
17 years 9 months ago #6632 by mega0079
pd.: it looks the same with other template :S
17 years 9 months ago - 17 years 9 months ago #6635 by core2
It seems like the css you attached has fixed width. Have a look at section /* MAIN LAYOUT DIVS and /* PRIMARY COLUMN. You can try to increase some of the widths, but this normally involve either good css skills or a lot of trails and error. Probably you have to edit some of the background images as well.
The default joomla template should work...
17 years 9 months ago #6675 by mega0079
thanks for the answer i have been modifing the values of /* MAIN LAYOUT DIVS and /* PRIMARY COLUMN but without a good ressult.
As you say with the default template of joomla this menu seems to be in the right position but i dont know which code i should move, i hope u can help me thanks a lot
