Question How can I have Kunena Forum in Full width
17 years 5 months ago #11467 by STi
Hello, I'm asking myself how to implement Kunena on muy joomla site but exactly as it shows here in kunena.com website? I use right column position for modules in joomla but when I invoke Kunena from a menu link it displays on the content side but with the right colums making the Kunena forum very shrink.
I'd like to have the forum in full width on mi site, as I said above, just like in this site. Is there any way to invoke Kunena from a menu link in joomla with a full screen width with no right or left modules ???
Thanks for the answers.
17 years 5 months ago #11468 by grumblemarc
This a commonly asked question so you really should search for the answer.
However the short answer is- Unpublish the left and right modules for the forum. This doesn't work if your Joomla template does not support collapsible module positions (aka SiteGround).
17 years 5 months ago - 17 years 5 months ago #11470 by STi
Hm yes that is the easy way heheh but the detail is that I use items on right column. I was wondering if I can modify some php or another settings or even have the forum in a new page without joomla related modules, just the forum alone. Thanks for the answer.
Last edit: 17 years 5 months ago by STi.
17 years 5 months ago #11478 by grumblemarc
Create a blank Joomla template and assign it to the forum.
17 years 5 months ago #11538 by kai920
You can edit your template's index.php with combination of PHP and CSS to achieve this. for example:
$option = JRequest::getVar('option','');
then, just above the </head> tag, add something like this
<?php if ($option == 'com_kunena') : ?>
-CSS statements to expand your main wrapper to 100% width.
-Hide any side columns.
<?php endif; ?>
17 years 5 months ago - 17 years 5 months ago #11869 by dswoboda
Can you elaborate on this a bit. Are you saying that you can have different pages in a Joomla site with different templates? I will have to look into that as I did not know that was possible.
I tried the following approach to make my forums span the full width, but it only worked partially.
I turned off the option to have a menu appear on all pages and used the manual assignment function to turn it off for my forum page only. I then made a special TOP menu for the forums and told it to only show on forums page.
This worked well UNTIL Joomla wanted to created a page (automatically) then there were NO menus on those pages. It happened on pages made from the READ MORE link, and most of the pages created with the mod AdsManager.
I had to change it all back to the original setup and just turn off any RIGHT col modules.
It appears that Joomla needs to have at least one menu assigned in my template. The template is the free JAMBA template from Joomla Shack.
I'd love to figure our your method of making a custom blank template with just my top my top banner and top menus, then assign that to the forums only.
Thanks,
-David Swoboda
Last edit: 17 years 5 months ago by dswoboda.
Time to create page: 0.218 seconds
