Question Installation Problem: Cannot create folder
17 years 8 months ago #6329 by Steel Rat
Hello all, new to Joomla, but not new to CMS apps.
I've got a fresh install of Joomla 1.5 installed successfully, and was hoping to try out Kunena forums.
I've chosen the route of uploading the install package and unpacking on the server, then installing from there. However, when I do so I get the following error:
* JFolder::create: Could not create directory * Component Install: Failed to create directory.: "/home/jalberts/public_html/joomla/administrator/components/com_kunena"
Even though the Joomla install didn't specify this, I went ahead and made the Components folder writeable (777), but the problem persists.
I did enable the Legacy plugin in Joomla.
Any thoughts?
Thanks!
Steel Rat
17 years 8 months ago #6364 by Matias
Did you also make
writable for all?
I ask this because it seems not to be writable for Apache.
17 years 8 months ago #6392 by Steel Rat
Thanks for the reply. I did just try that, and still get the same error. Though in my experience it's the endpoint folder permissions that are important, not the upstream folders.
Is there any way I can place the files in the proper place manually, and then point to the install location?
FYI. I also tried the local file upload and install (using the tar.gz archived version), and get the following error:
* Warning! Failed to move file. * JFile::read: Unable to open file: '/home/jalberts/public_html/joomla/tmp/com_kunena_v1.0.8_b1166_2009-02-17.tar.gz' * Unable to read archive
17 years 8 months ago #6397 by fxstein
Your Joomla install does not appear to be clean.
No you should not copy files manually.
Is it possible that you are running Joomla with the FTP layer enabled? This is a common source for issues as a different userid and group is used by the installer than what is running the webserver.
I highly recommend you get onto the Joomla forums and read up on security and setup of Joomla. It is not a solution for files to be manually copied around nor to open up directories to 777.
Hope this helps!
fxstein
17 years 8 months ago #6404 by Steel Rat
I did not enable the FTP layer when I installed Joomla. I'll delete everything and try again. Will let you know the results.
Thanks again for the replies.
Steel Rat
17 years 8 months ago #6410 by Steel Rat
Ok, I'm re-installing Joomla, and the text during the install for the FTP setup seems to indicate that for linux/unix systems you SHOULD enable FTP. What am I missing here?
