Question File upload problem
Not Found
The requested URL /media/kunena/attachments/legacy/files/blah.mp4 was not found on this server.
I have added mp4 as a permitted file type and it is smaller than the file size limit.
Can you find the file from there?
Are your directory permissions ok?
PHP Version = 5.2.8
MySQL = 5.0.67-community
/public_html/media/kunena/attachments/legacy/files/ directory is set to 777
The /public_html/media/kunena/attachments/legacy/images/ is also set to 777 and it works fine.
I tried uploading a 4meg mp4 file, currently using default PHP settings (8 meg max)
First you should check these:
Kunena Configuration / Uploads / File:
File types allowed = mp3,mp4 (and other allowed filenames)
Max. File size = 8096
If they are ok, you should check that there will be no php timeout when posting.
And if even that is ok, try to look if you get any php warnings/errors into your Apache log.
Also try to upload small file. Does it work?
Yes, it must be a file restriction somewhere, as I can upload mp4 files up to 1meg, but not 2 meg.
I will have a look through Kunena settings, PHP settings and Apache settings
