Question Fatal error when installing Kunena
Also when i go to the admin section of it, there fatal errors and part that dont display correctly.
Please let me know what other info you need from me. Thanks. I hope i can get this to work!!!
Actually I did have FB installed a while ago. Does that change any of the steps you posted above?
Yes, if you had FB installed previously, DO NOT drop the existing fb_ tables. That would delete all your forum data.
At that point, you should just be able to install Kunena 1.0.8 just as Matias said above and it should go fine.
Let us know if this is not the case.
Thnaks!
Everything is broken as before.
I am going to try the phpmyadmin thing and report back.
