Question SMF to Kunea
17 years 9 months ago #2670 by sankuri
SMF to Kunea was created by sankuri
Guys exist some converter from SMF to Kunea?
17 years 9 months ago #2689 by woonydanny
Replied by woonydanny on topic Re:SMF to Kunea
not at present. Converters will come later once a stable build has been released and the new api framework is done i believe.
In the meantime, go to BOJ and look for SMF to Fireboard converters and then upgrade your FB to Kunena.
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
17 years 9 months ago #2690 by sankuri
Replied by sankuri on topic Re:SMF to Kunea
Ok that can be, but all download links on fireboard pages are broken. Can anyone upload SMF -> FB converter here or some ftp?
17 years 9 months ago #2692 by fuqaha
Replied by fuqaha on topic Re:SMF to Kunea
I would like to request the same thing. I have a SMF forum with just over 30k posts and 2k users that I want to convert to Kunena due to good Jomsocial + Kunena integration.
As sankuri mentioned, the link over there is broken, can anyone upload it here or at any site? Thanks.
17 years 9 months ago #3228 by fred2
Replied by fred2 on topic Re:SMF to Kunea
Hi.!
I used smf2fb and for me worked perfectly. Only users not imported, but you can import before. I just imported 40k posts and no problem.
You must do some stetic cleanups in text of database, example remove and replace all <br /> for \r\n and things like that. If you have a few experience edditing db text you will do without any problem.
I hope this will help somebody, here is the small script.
Fred
File Attachment:
File Name: smf2fb.zip
File Size:3.9 KB
17 years 8 months ago - 17 years 8 months ago #7539 by Helrunar
Replied by Helrunar on topic Re:SMF to Kunea
Hi fred,
Can you write a litte bit more about the things to change?
As example what is all to change and how :blush:
greetings
Edit:ok, i've got it :woohoo: It's so simple. In phpmyadmin do
update jos_fb_messages_text set message = replace(message,'<br />','\r\n')
Two Forums on one Site? Use the Kunena-Clon
Last edit: 17 years 8 months ago by Helrunar.
