Question Error after installing jomsocial
17 years 9 months ago #2325 by Hillbilly
I had The forum Kunena on my site and it worked fine. After Installing and setting uo Jomsocial all heck broke loose. I can't access the Admin Kunena and i'm getting this error.
Warning: require_once(/home/pdictek/public_html/components/com_community/libraries/core.php) [function.require-once]: failed to open stream: No such file or directory in /home/pdictek/public_html/components/com_kunena/class.kunena.php on line 45
Fatal error: require_once() [function.require]: Failed opening required '/home/pdictek/public_html/components/com_community/libraries/core.php' (include_path='.:/usr/local/php52/pear') in /home/pdictek/public_html/components/com_kunena/class.kunena.php on line 45
Tried unistalling and reinstalling the forum.
Really new at this.
Thanks for any help
17 years 9 months ago #2332 by grumblemarc
It's probably a permissions error or an incomplete install. Check those first.
17 years 9 months ago #2335 by Hillbilly
Tried reinstalling again, still coming up with the same error.
17 years 9 months ago #2348 by grumblemarc
Did you check the permissions?
17 years 9 months ago #2387 by Hillbilly
Fixed it! The hard way. Thanks for the help.
17 years 9 months ago #2388 by spacereactor
how is your hard way, can explain how you do it?
