Important Apache Rewrite Rule
17 years 8 months ago #1492 by fendermb4
Is anyone who is savvy with rewrite rules able to come up with one so that we aren't returning so many 404's to the search engines?
I upgraded to Kunena a couple days ago, and my logs are just full of 404's being returned to the bots.
17 years 8 months ago #1495 by Matias
Replied by Matias on topic Re:Apache Rewrite Rule
Rewrite rules is one of our top priorities for 1.0.8. So they will be included into release.
17 years 8 months ago #1537 by fendermb4
Replied by fendermb4 on topic Re:Apache Rewrite Rule
Thanks.
Just in case anyone is looking for a quick temporary fix, this seems to do the trick:
RewriteRule ^(.+)com_kunena(.+) $1com_kunena$2 [R=301,NC,L]
Thanks to this thread:
www.pragmaticutopia.com/component/option...id,5/id,12129/#12131
It might not be the best way, but it seems to be a good band aid until 1.0.8 is released with proper rules.
17 years 8 months ago - 17 years 8 months ago #2373 by steve
Replied by steve on topic Re:Apache Rewrite Rule
Nice work however I had a problem with it, maybe because I have joomla in a subdirectory.
After the following change to the path it seems to work ok.
YOUR SUBDIRECTORY GOES HERE/component/
RewriteRule ^(.+)com_kunena(.+)$ /YOUR SUBDIRECTORY GOES HERE/component/$1com_kunena$2 [R=301,L]
Note: This is with standard Joomla SEF enabled on joomla 1.0+.
Hope this helps until Kunena 1.0.8 is released. :)
Last edit: 17 years 8 months ago by steve.
17 years 8 months ago #3025 by FidelGonzales
I had this working on another script and under different parameters after a lot of trial and error, but I am having trouble getting my SMF to Kunena to work. Note, I am also in a sub-directory (/powersports/)
Since I was using OpenSEF, I have two different URLs I was working with, being that certain links would cause OpenSEF to jump from the Joomla default SEF URL to rather than OpenSEF URL. At the very least, though, I would like to get something working before I finish the migration from Joomla 1.0 to Joomla 1.5 along with a migration from SMF to Kunea.
Instead of continuing with what I have so far and instead using your rewrite rule as a basis, do you believe these suggestions would work? It seems the default Joomla SEF is an easy fix, but the OpenSEF URLs have been giving me a hard time. Thanks.
JOOMLA SEF
www.MYSITE.com/powersports/component/opt...emid,31/board,150.0/ -
RewriteRule ^(.+)com_smf(.+)$ /powersports/component/$1com_kunena$2 [R=301,L]
OPEN SEF
www.MYSITE.com/powersports/forum/board,150.0/
RewriteRule ^(.+)forums(.+)$ /powersports/component/$1com_kunena$2 [R=301,L]
17 years 8 months ago #5503 by woonydanny
Replied by woonydanny on topic Re:Apache Rewrite Rule
Did this occur or do we need still add a rule to our .htaccess file?
If so which one to redirect fireboard to kunena?
I guess i will have to do a find and replace in my database as well for all the links written in my forum so they now point to kunena?
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
