Question I installed the wrong Kunena eek
17 years 7 months ago #13521 by journeyoftheanimals
Well I recently changed over my site to Joomla 1.5 and when I did that I installed Kunena and was using fireboard before that. However I was trying to change some things around on the forums such as colors and stuff and noticed I installed the wrong version of Kunena. I believe I installed 1.5. So I have the beta version on my site. Would I be able to just install the stable version of Kunena and have all the posts on my forums on the stable version with out too many problems?
I hope that my post was understandable. I am in a bit of a rush.
17 years 7 months ago #13526 by Lintzy
Please backup your database and files befor downgrading (you should always make backups before changing a system).
Then deinstall Kunena 1.5.0 and install Kunena 1.0.9. It should work. Kunena 1.0.9 does work with Joomla legacy not native (as reminder).
17 years 7 months ago - 17 years 7 months ago #13565 by journeyoftheanimals
How do I go about uninstalling? Never have been able to figure out how to uninstall stuff in Joomla.
Edit*
Nevermind that was pretty obvious.
Last edit: 17 years 7 months ago by journeyoftheanimals.
17 years 7 months ago #13567 by Lintzy
Joomla Backend -> Extensions -> install/uninstall
choose components - > Kunena
17 years 7 months ago #13672 by mikx
hello
I have really annoying problem
First I have installed kunena 1.5 and uninstall it and installed 1.0.9 for sseveral times and it always shows that is version 1.5 installed
I tried to erase all folders of kunena and it didnt help
can anyone help me to completely unistall this kunena and install fresh new 1.0.9
thanx
17 years 7 months ago #13673 by Lintzy
This is a known bug, you have installed 1.0.9 only the notice did not change. The DEVs will fix this in one of the upcoming releases.
