Question Can not be installed on the localhost
17 years 7 months ago #13146 by indrameissa
Hello admin, I want to ask something to the installation problem that occurred on the localhost, when I do the installation on localhost failed and it always appears that only a white blank page, so about the problem exists on the part what?
17 years 7 months ago #13147 by sozzled
What version of Kunena? What version of Joomla? What version of PHP, MySQL and Apache webserver are you running on your PC?
17 years 7 months ago #13149 by indrameissa
Yes, all versions that I use is the latest version from kunena version 1.0.9, joomla version 1.5.10 and webserver from wampserver latest at this time. Webserver running well, to the installation of other components that do not have trouble, just when I do kunena installation always fails, what is there to help me?
17 years 7 months ago #13150 by sozzled
I think you'll find this item useful: www.kunena.com/forum?func=view&catid=16&id=12929#13029
It's possible that the problem has to do with making sure your "webserver has the mbstring extension loaded". Because you can control your WAMP installation, you should be able to configure your PHP settings appropriately and cure the "blank page" symptom that's probably caused by Joomla 1.5.10.
17 years 7 months ago #13151 by indrameissa
No, I do not find the occurrence of error during installation kunena, only me when I do the installation always fails and does not find the occurrence of error. :dry:
17 years 7 months ago - 17 years 7 months ago #13152 by sozzled
Have you checked, as the discussions I referred to, that you have the mbstring extension loaded for Joomla 1.5.10 as recommended by fxstein? You should also turn on Joomla debug mode. Report the errors that you "blank page" has (if any).
Last edit: 17 years 7 months ago by sozzled.
Time to create page: 0.146 seconds
