Question Possible Kunena Latest Issue?
13 years 3 months ago - 13 years 3 months ago #147049 by PhoenixUK
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : rt_alerion | author: RocketTheme, LLC | version: 1.1 | creationdate: Unknown
Kunena default template details : NTS KMonazite | author: Nice Theme Store | version: 3.0.0 | creationdate: 2013-05-24
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party components: CommunityBuilder 1.9 | UddeIM 3.0
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
Last edit: 13 years 3 months ago by PhoenixUK.
The topic has been locked.
13 years 3 months ago #147050 by PhoenixUK
I've found an issue it seems with Kunena Latest module.
It seems to be the cause of me getting the following error on my homepage, where I have a Kunena Latest module published.
It's long winded but you can read up about the more in depth explanation including screenshots, as to how I found the problem and I'm hoping with the config report above and also the RocketTheme forum post , that you can guide me towards a resolution for the issue as I'm now none the wiser I'm afraid.
I look forward to hearing from you in due course.
Regards,
Rob
13 years 3 months ago #147053 by Jiminimonka
I renamed this topic to something relevant to your suspected issue. Not sure if this is at all related to Kunena, but I will ask the devs to take a look.
Please read the FAQ.
Only one question per topic.
13 years 3 months ago #147062 by PhoenixUK
Jimi,
Ok no worries and thanks. I was just following the Subject Title it said to put in the Video Tutorial about submitting Config Reports, my apologies although it's the first one I've ever done.
It would be good for the Devs to look in to it definitely, as soon as I turn on that Kunena Latest Module, that's ultimately what then knocks my homepage out, which is the only page where I use this module at present.
I look forward to the feedback.
Regards,
Rob
Jiminimonka wrote: I renamed this topic to something relevant to your suspected issue. Not sure if this is at all related to Kunena, but I will ask the devs to take a look.
13 years 3 months ago - 13 years 3 months ago #147065 by sozzled
Nothing actually leaps out of your configuration report the 3rd-party Kunena template and your forum integration plugin settings. I recommend you change the forum integration plugin settings (as indicated below in red):
Kunena - Community Builder Enabled: access=0 login=1 activity=1 avatar=1 profile=1 private=0
Last edit: 13 years 3 months ago by sozzled.
13 years 3 months ago #147066 by PhoenixUK
Hi Sozzled,
Thanks for the reply, so just to re-iterate you're in effect asking me to disable the main Kunena extension and then what?
Regards,
Rob
sozzled wrote: Nothing actually leaps out of your configuration report the 3rd-party Kunena template and your forum integration plugin settings. I recommend you change the forum integration plugin settings (as indicated below in red):
Kunena - Disabled
Time to create page: 0.160 seconds
