Question Location of messageButtons class?
10 years 5 months ago #176531 by jhebbel
Trying to change the output of message buttons such as $this->messageButtons->get('delete') but the location of the function is not where I thought it would be. If you want to modify this functions html output, where should I be looking?
10 years 5 months ago #176532 by 810
The following user(s) said Thank You: jhebbel
10 years 5 months ago #176533 by jhebbel
810 wrote: github search, is your friend:
github.com/Kunena/Kunena-Forum/search?ut...%93&q=messageButtons
So one of the reasons I wanted to know is a lot of my buttons are missing icons. I see from here that the display of the icons is determined by $topicicontype. Where in the UI I this var set because I have been unable to find it.
10 years 5 months ago - 10 years 5 months ago #176534 by 810
its on the template settings - features - topic icons
Last edit: 10 years 5 months ago by 810.
10 years 5 months ago #176535 by jhebbel
810 wrote: its on the template settings - features - topic icons
Found it, not sure how I overlooked it. May I recommend adding glyphs as an option, its what I was expecting since the rest of the forum seems to leverage glyphs.
10 years 5 months ago #176536 by 810
glyphs is B3 ;)
