- Thank you received: 4
Solved K 3.0 Kunena Discuss: how to use
13 years 4 months ago #144368
by jeyjey
K 3.0 Kunena Discuss: how to use was created by jeyjey
When I install a plugin I go to installations manager and I choose to open the plugin. Then, during the "enabling" operation, I see the plugin tag to insert in articles. I do not found it everywhere. I read the Wiki and there is not the usage of the Discuss Plugin. How can I invoke (call) the forum thread to discuss to? Where and how I mention in a content where the thread is? Thanks.
13 years 4 months ago - 13 years 4 months ago #144464
by gray
www.justPHP.net - Custom coding for Joomla!
Replied by gray on topic K 3.0 Kunena Discuss: how to use
Have you check this article -
www.kunena.org/docs/Kunena_Discuss:_Installation_and_Use
It's for an older version, but principle and configuration remained the same.
Last edit: 13 years 4 months ago by gray.
13 years 4 months ago #144478
by jeyjey
Replied by jeyjey on topic K 3.0 Kunena Discuss: how to use
I read that Wiki article, but I meaning that it is not wrote HOW call the forum post or link to the forum thread. For example if I use other joomla plugin I must insert some tags like this:
. Whit this plugin I can configure it sure, I read it, but what is the calling code to put inside the article text? Thanks.
{widgetkit Identifier}
13 years 4 months ago #144492
by ritesh_z
Replied by ritesh_z on topic K 3.0 Kunena Discuss: how to use
Try this:
1. Go to Kunena Forum and Create a new Category: "Test".
2. Save it and find out the ID assigned to it. Let's say it's 164.
3. Go to Plugins and open Kunena Discuss.
4. Click Basic Options tab from top.
5. Scroll to the text box that says "Default Forum Category" and type 164 in it.
6. Save it and you're good to go.
7. Just open any article from your site and all articles will immediately move to Test category in your forum.
8. You don't need to include code that includes curly braces anywhere in your articles. It applies to all articles by default but you can configure it under Basic Options.
9. Once this works out, try out the other options under Basic tab.
The following user(s) said Thank You: jeyjey
13 years 4 months ago #144498
by gray
There is an option "Allow Custom Topics" which allows using {tag}:
Tip: Enable this option if you would like to arbitrarily discuss an article in an existing topic. You can then add {kunena_discuss:#} tag anywhere to your article, where # is topic Id in Kunena. If you do not want to discuss this article, use {kunena_discuss:0}.
Instead of adding {kunena_discuss} to every article you can use "Category Mapping" (different article categories go to different forum ones - I've created a hack to map parent content categories ) option or "Default Forum Category" option (all discussions from allowed content categories will go to a single forum category).
13 years 4 months ago #144499
by Mortti
Replied by Mortti on topic K 3.0 Kunena Discuss: how to use
Time to create page: 0.367 seconds
