- Thank you received: 1
Solved Plugin 'Smart Search - Kunena Forum' SQL error in Maintenance - Optimise
4 years 2 weeks ago - 4 years 2 weeks ago #225274
by toivo
Expected behaviour
Smart Search - Maintenance - Optimise runs normally.
Actual behaviour
1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 5
Workaround
Disable the 'Smart Search - Kunena Forum' and Maintenance - Optimise runs normally.
Environment
Kunena 6.0.2 2022-08-15
Joomla 4.2.3-dev
PHP 8.1.9
MySQL 8.0.27
Wampserver 3.2.9
Windows 11
Actual behaviour
Workaround
Environment
Joomla 4.2.3-dev
PHP 8.1.9
MySQL 8.0.27
Wampserver 3.2.9
Windows 11
Last edit: 4 years 2 weeks ago by toivo. Reason: typo
4 years 2 weeks ago #225275
by xillibit
Replied by xillibit on topic Plugin 'Smart Search - Kunena Forum' SQL error in Maintenance - Optimise
Thanks for the report i will take a look
4 years 2 weeks ago #225277
by toivo
Replied by toivo on topic Plugin 'Smart Search - Kunena Forum' SQL error in Maintenance - Optimise
Here is the call stack, if that helps:
An error has occurred.
Call stack
# Function Location
1 () JROOT\libraries\vendor\joomla\database\src\Mysqli\:137
2 mysqli->prepare() JROOT\libraries\vendor\joomla\database\src\Mysqli\:137
3 Joomla\Database\Mysqli\MysqliStatement->__construct() JROOT\libraries\vendor\joomla\database\src\Mysqli\:1048
4 Joomla\Database\Mysqli\MysqliDriver->prepareStatement() JROOT\libraries\vendor\joomla\database\src\:1900
5 Joomla\Database\DatabaseDriver->setQuery() JROOT\administrator\components\com_finder\src\Indexer\:281
6 Joomla\Component\Finder\Administrator\Indexer\Adapter->onFinderGarbageCollection() JROOT\libraries\src\Plugin\:279
7 Joomla\CMS\Plugin\CMSPlugin->Joomla\CMS\Plugin\{closure}() JROOT\libraries\vendor\joomla\event\src\:486
8 Joomla\Event\Dispatcher->dispatch() JROOT\libraries\src\Application\:107
9 Joomla\CMS\Application\WebApplication->triggerEvent() JROOT\administrator\components\com_finder\src\Controller\:58
10 Joomla\Component\Finder\Administrator\Controller\IndexController->optimise() JROOT\libraries\src\MVC\Controller\:672
11 Joomla\CMS\MVC\Controller\BaseController->execute() JROOT\libraries\src\Dispatcher\:143
12 Joomla\CMS\Dispatcher\ComponentDispatcher->dispatch() JROOT\libraries\src\Component\:355
13 Joomla\CMS\Component\ComponentHelper::renderComponent() JROOT\libraries\src\Application\:143
14 Joomla\CMS\Application\AdministratorApplication->dispatch() JROOT\libraries\src\Application\:186
15 Joomla\CMS\Application\AdministratorApplication->doExecute() JROOT\libraries\src\Application\:294
16 Joomla\CMS\Application\CMSApplication->execute() JROOT\administrator\includes\:61
17 require_once() JROOT\administrator\:32
Call stack
# Function Location
4 years 2 weeks ago #225281
by xillibit
Can-you confirm that you have just enabled the smart search plugins for Kunena and Joomla!, but not others plugins ?
4 years 2 weeks ago #225287
by toivo
All the six (6) standard Joomla Smart Search plugins plus Smart Search - Kunena Forum were enabled. All the Kunena plugins were enabled, except Jomsocial, Community Builder, EasySocial and Gravatar integration plugins.
4 years 2 weeks ago #225288
by xillibit
I'am not able to reproduce it, so to try to get the query open the file : /libraries/vendor/joomla/database/src/DatabaseDriver.php and at line 1857 add :
Then re-try the optimise
echo 'query '.$query;
Time to create page: 0.245 seconds
