Question Forum will not get "offline" when set to "public"
6 years 4 months ago #213617 by pendley
I have changed backend configuration for forum "online" and tried to make available for public view, not registered.
Changed everything - but will not come online to public visitors, keeps giving message "forum is offline."
Help much appreciated.
Recently moved all to a new dev subdomain.
Cleared all cache.
tried new menus.. ?
thanks.
JP
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : Clever1 | author: | version: 3.2 | creationdate: July, 2013
Kunena default template details : NTS KTrend | author: Nice Theme Store | version: 1.1.0 | creationdate: 2020-06-07
Kunena template params:
Kunena version detailed: Kunena 5.1.17 | 2020-06-09 [ Quaoar ]
Third-party components: CommunityBuilder 2.4.5 | UddeIM 4.0
Plugins: None
6 years 4 months ago #213623 by 9themestore
Please provide to me the site information, We will try to help you check this issue.
The following user(s) said Thank You: pendley
6 years 4 months ago #213624 by pendley
thanks.
What do you request? I dont understand.
The site wont go Public. It was recently removed to another dev subdomain, while work is in progress.
Do you need an admin access?
thanks.
JP
6 years 4 months ago #213625 by pendley
Bear with me.
I've sent you guys a few $$ the last week. I should hope that might be of some consideration.
please see:
cfmdev1.catfishfridaymusic.com/index.php/bah1/nda-k
Otherwise - I"m stuck. thanks for understanding.
JP
6 years 4 months ago #213626 by Leen
Hi
it seems that your security certificate is no longer
valid your link gives warnings in web browsers that website is not safe
The original certificate provided by the web server is untrusted.
With kind regards
Leen
6 years 4 months ago #213629 by rich
This message is also displayed if the Kunena installation is incomplete. During an installation or upgrade set Kunena the forum offline. Maybe an upgrade isn't complete. Try to install again Kunena.
Your second problem are the menu items. All red marked menu items are wrong (I can't see a target). It seems, the menu items 230, 122 and 598 does not exist. Please repair the menu items.
docs.kunena.org/en/troubleshooting/menu-issues
docs.kunena.org/en/faq/kunena-menu
Time to create page: 0.183 seconds
