Important Rights problem...
10 years 5 months ago - 10 years 5 months ago #176245 by Elnablo
Rights problem... was created by Elnablo
Please check here .
In KUNENA 4.x guests where allowed to write a message (it's the way I set it up). The buttons needed to start a new post do not show anymore in 5.x until I log in (admin). This is not the correct behavior.
Basically the same problem as my post here .
Guest should be able to "see" the entries and if it so set up, add a post.
INFO: Worked in 4.x and stop working in 5.x!
Last edit: 10 years 5 months ago by Elnablo.
10 years 4 months ago #177067 by Elnablo
Replied by Elnablo on topic Rights problem...
Still not working in RC5.
10 years 4 months ago #177069 by 810
Replied by 810 on topic Rights problem...
please add kunena report
10 years 4 months ago #177098 by Elnablo
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 92M | Max file upload: 38M
Joomla default template details : jsn_dona_pro | author: JoomlaShine.com | version: 1.1.1 | creationdate: 04/20/2016
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.0-RC4 | creationdate: 2016-07-08
Kunena version detailed: Kunena 5.0.0-RC4 | 2016-07-08 [ RC4 ]
Plugins: None
Modules: Kunena Latest 3.1.2.1 | Kunena Login 3.1.2
10 years 4 months ago #177100 by rich
Replied by rich on topic Rights problem...
Go to your Kunena configuration and choose at tab security "Allow Guests to Post/Write = Yes".
The following user(s) said Thank You: Elnablo
10 years 4 months ago #177102 by 810
yes indeed, you need to turn on the option. I see now: pubwrite = 0
