Solved Pagination doesn't work
9 years 3 months ago #194762 by Daviciacus
I have recently upgraded my Joomla 2.5 website to Joomla 3, and also Kunena to the latest version.
I notice that the pagination is no longer working properly. When a topic has more than one page, and I click on e.g. page 2 or 3, I end up at the home page of my Joomla website instead each time.
I have already googled the issue, but haven't found any solution yet that worked.
A few things I tried:
- Installed Kunena again (even with chmod to 777 for /com_kunena/ as I read somewhere that fixed it, but not for me)
- Tried another template, same result
- Tried disabling Joomla SEF, same result (I do not have other SEF plugins installed)
- Tried to create a new Kunena Category menu item, used that to load the forums and tried again, same result
- Joomla's error reporting to "maximum" gives no Kunena errors
- Kunena Diagnostics gives no errors
I really don't know what to do anymore, but my site needs to live again very soon so I hope this can be fixed quickly.
Thanks.
My report configuration is:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 16M
Joomla default template details : eco | author: joomladesigns.co.uk | version: 3.0.1 | creationdate: 30/04/2014
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.0.3 | creationdate: 2017-02-04
Kunena template params:
Kunena version detailed: Kunena 5.0.10 | 2017-06-30 [ Junco ]
Third-party components: CommunityBuilder 2.1.3+build.2017.08.10.23.23.10.914ce3ace | UddeIM 3.9
Plugins: None
Modules: Kunena Latest 5.0.3
9 years 3 months ago #194764 by rich
Replied by rich on topic Pagination doesn't work
Please remove the obsolete menu items from your trash. You use a multilingual web page? I see menu items "nl" and "english" in your configuration report. Unfortunately I can not see your page but maybe it's because of it?
9 years 3 months ago #194765 by Daviciacus
Replied by Daviciacus on topic Pagination doesn't work
I have just now deleted the menu items that were in the trash. This did not fix the problem.
I have also tried to set the forum menu link to "public" (it's not supposed to be public but for members only, always that way), but this also did not fix the problem.
The website is currently completely offline because I had upgraded to Joomla 3 and I want to put it back online asap when the issues like this one are fixed.
When I (temporarily) put the website online, then log in with a regular test user account, and try the pagination, I get a 404 Page not found error instead of going to the home page.
It appears that the issue only comes up with &start=20 (or other number) is added to the URL. But the additional replies are definitely there, because if I set in Kunena configuration the amount of replies per page to e.g. 50 or more, they all show up.
P.S. The pagination for multiple pages among the topic list has the exact same issue.
9 years 3 months ago #194766 by Daviciacus
Also, yes my site is bi-lingual EN/NL, but when I try the pagination in either language, the result is the same :(
9 years 3 months ago #194767 by rich
Please go in the backen to "Extensions -> Manage -> tab Database" and check if it's ok. And if you have enabled in the Joomla global configuration "Adds Suffix to URL", then disable it.
9 years 3 months ago #194768 by Daviciacus
In the tab Database, it's saying everything is ok (I had already done "fix" right after the upgrade, and did again just now but the pagination issue remains).
Adds suffix to URL is already disabled, as well as Use URL Rewriting.
Time to create page: 0.166 seconds
