Solved Banners between posts
9 years 11 months ago #182400 by uzbaby
Banners between posts was created by uzbaby
Hello dears!
How can I add banners or some other advertisings between kunena posts.
I googled and found one solutiong but it doesnt work. It was to ad kunena_msg_1 position and write code. I did it but nothing works.
Any help?
9 years 11 months ago #182409 by 810
Replied by 810 on topic Banners between posts
yes, like kunena_msg_1 but I think you forgot to enable it on all pages. please check the settings.
9 years 11 months ago #182413 by rich
Replied by rich on topic Banners between posts
kunena_msg_1 is a absolute position. msg_1 is only the first message of a topic.
Try it with position kunena_msg_row_1. I think that is what you want ( Module Positions ).
9 years 11 months ago #182493 by uzbaby
Replied by uzbaby on topic Banners between posts
The problem is when I want to set position and write kunena_msg_1 or kunena_msg_row_1 it doesnt't set there. There is words like Add kunena_msg_1 position, but I can't push it or choose it or set it. It appears as NONE. A did enabled to all positions.
9 years 11 months ago #182502 by rich
You must press Enter, otherwise you can't set it. Enter the position -> press Enter -> save it
9 years 11 months ago #182504 by uzbaby
Dear rich ..yes I did pressed the enter maybehundred times..it doesnt work
