Solved K 4.0.3 Crypsis "automatically" subscribes to topic; Blue Eagle does not
11 years 2 months ago #167809 by sozzled
I have the following configuration setting:
Configuration » Users » Subscriptions » Check Subscription Box = No
I do not want the "Check this box to be notified of replies to this topic" checkbox to be checked, by default (as you see here, on the forum at www.kunena.org .
The configuration settings are here:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Crypsis | author: Kunena Team | version: 4.0.3 | creationdate: 2015-06-29
Kunena version detailed: Kunena 4.0.3 | 2015-06-29 [ Possagno ]
Plugins: None
Modules: Kunena Latest 3.1.1
I conducted the following test of K 4.0.3. Using K 4.0.3 Blue Eagle, this the following screenshot shows what appears on my site before pressing the submit button:
The following screenshot shows what happens after pressing the submit button.
The message is posted and the user is not subscribed to the topic. In other words, the configuration setting works with K 4.0.3 Blue Eagle.
I then changed the template to use K 4.0.3 Crypsis. This is the configuration report after the change:
Plugins: None
Now look at the following screenshot that shows that the "Check this box to be notified of replies to this topic" checkbox is now checked
This is not what is wanted. The following screenshot shows that, after pressing the submit button, the user is now subscribed to the topic!
This demonstration shows that the configuration setting
does not work if you use the Crypsis template in K 4.0
11 years 2 months ago #167824 by 810
you need to update to k4.0.5, then its fixed.
11 years 2 months ago #167862 by sozzled
810 wrote: you need to update to k4.0.5, then its fixed.
What do you mean "it's fixed"? When was it broken?
I have looked through the release notes for all versions of K 4.0 and I cannot find where the new "feature" was added.
I have looked at the release notes for K 4.0.5 and I cannot see where the "fix" was implemented.
The issue is simple. Does the setting
have any meaning in K 4.0 Crypsis? If this setting means something, what does it do and is there any documentation about how to turn on/off the subscribe checkbox? I have a couple of customers who have asked me about this issue because they are concerned about a potential impact on privacy laws.
11 years 2 months ago - 11 years 2 months ago #167865 by 810
What was broken, was the checkbox,
it doesn't taking the setting before, different choices between newtopic/reply.
"•Subscribe's box is always enabled #3303"
github.com/Kunena/Kunena-Forum/pull/3304
The setting is working now on all default templates. 3rt party template builders must update their template to.
Default new user is "-1"
"-1" = Kunena config setting
"0" = disabled on user setting
"1" = Enable on user setting
Last edit: 11 years 2 months ago by 810.
11 years 2 months ago #167868 by rich
Kunena 4.0.4 Read Me
*Subscribe's box is always enabled #3303
This setting has always been there. The user could always select the checkbox self, if subscription is allowed. Now he has this setting also in his profile. What has that to do with privacy laws?
11 years 2 months ago #167869 by sozzled
Thanks for the reply. I still do not understand what you mean.
I looked at the setting
In K 4.0.3 it has two possible values: Yes and No. Irrespective of either setting, the checkbox is always enabled in K 4.0.3 Crypsis.
In K 4.0.5 the setting
still has two possible values (Yes and No). If I understand you correctly, this setting applies to setting the profile settings for new users who register after K 4.0.3. Is that correct?
If I understand you correctly, the user profile setting determines if the checkbox is checked or not checked for Crypsis and Blue Eagle. Is that correct?
If I understand you correctly, the user profile setting is initialised by the configuration setting. (The default value of the configuration setting is Yes; therefore user profiles created after K 4.0.x will most probably inherit the default, i.e. "yes").
If I have misunderstood something I would appreciate your advice as to how to best use these features.
I notice that there is no mention of these changes (or its fix) in the K 4.0.4/K 4.0.5 release notes.
Time to create page: 0.211 seconds
