Question Error 1054 Unknown column 'id'
10 years 4 months ago #177587 by Chelsea FC
Hi Kunena Team,
i got a Problem with my Kunena.
First i updated Joomla from 1.5 to 3.6 with SP Upgrade 4.0.6.
Than install the new Kunena on new Site with new Joomla, Transfered User and all Stuf from old Joomla.
Than Transfered Old Kunena User, Posts, Topic etc. to new Kunena.
When i go to components ---> Kunena than comes a Error:
1054 Unknown column 'id' in 'where clause' SQL=SELECT * FROM #__kunena_configuration WHERE id=1
Any idea how to solve this Problem? Please help.
Thank you.
10 years 4 months ago #177588 by 810
Replied by 810 on topic Error 1054 Unknown column 'id'
Looks like you miss the sql table.
Please add this code on your database, and change the yourprefix with your own prefix:
CREATE TABLE IF NOT EXISTS `yourprefix_kunena_configuration` ( `id` int(11) NOT NULL default '0', `params` text NULL, PRIMARY KEY (id) ) DEFAULT CHARACTER SET utf8;
The following user(s) said Thank You: Chelsea FC
10 years 4 months ago #177589 by Chelsea FC
Thank you,
which database? As a new Table? inside _kunena_configuration?
Thanks.
10 years 4 months ago #177590 by 810
into the joomla database, where you have all the website tables.
You need to copy the code into the sql tab and run it.
10 years 4 months ago - 10 years 4 months ago #177612 by Chelsea FC
Thanks.
So i go to phpMyAdmin.
inside the Database.
At the header i click on the Tab "SQL".
i see a empty field. so copy and paste
CREATE TABLE IF NOT EXISTS `tg09a_kunena_configuration` (
`params` text NULL,
Than click on ok.
than i see green field with text in german: MySQL lieferte ein leeres Resultat zurück, means like MySQL gave back an empty result
i go back to joomla backend, reload the site and go to Components --> Kunena Forum = nothin happen. same problem with the error text.
Last edit: 10 years 4 months ago by Chelsea FC.
10 years 4 months ago #177613 by 810
I suggest to create a full backup. data + databse
Then remove all kunena tables, then export the kunena tables from your J1.5
Then import it into you new database, check the tables if they have the correct prefix. Then install kunena package by the joomla installer.
