Solved Installation issue
11 years 3 weeks ago #169902 by Budrys
Installation issue was created by Budrys
When I tried to install Kunea I got that error:
Niestety instalacja nie powiodła się z powodu następującego błędu:
Notice: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in /home/betty71/domains/betty71.pro-linuxpl.com/public_html/wduchu35/administrator/components/com_kunena/install/schema.php on line 12 Notice: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in /home/betty71/domains/betty71.pro-linuxpl.com/public_html/wduchu35/administrator/components/com_kunena/install/schema.php on line 13 Warning: DOMDocument::load() [domdocument.load]: I/O warning : failed to load external entity "/home/betty71/domains/betty71.pro-linuxpl.com/public_html/wduchu35/administrator/KPATH_ADMIN/install/install.xml" in /home/betty71/domains/betty71.pro-linuxpl.com/public_html/wduchu35/administrator/components/com_kunena/install/schema.php on line 206 Notice: Trying to get property of non-object in /home/betty71/domains/betty71.pro-linuxpl.com/public_html/wduchu35/administrator/components/com_kunena/install/schema.php on line 281 Warning: Invalid argument supplied for foreach() in /home/betty71/domains/betty71.pro-linuxpl.com/public_html/wduchu35/administrator/components/com_kunena/install/schema.php on line 296 Fatal error: Class 'KunenaRoute' not found in /home/betty71/domains/betty71.pro-linuxpl.com/public_html/wduchu35/administrator/components/com_kunena/install/sql/install/php/sampledata.php on line 147
11 years 3 weeks ago #169904 by 810
Replied by 810 on topic Installation issue
Go to joomla plugins manager, and enable the system-kunena plugin.
11 years 3 weeks ago #169907 by Budrys
Replied by Budrys on topic Installation issue
I don't have that plugin on my Joomla.
11 years 3 weeks ago #169908 by 810
try
1) use the install by url option: github.com/Kunena/Kunena-Forum/releases/...4.0.6_2015-09-28.zip
2) Or unzip the download, and install the plugin, its in the package dir. Then enable the plugin, and try to install the main package again.
11 years 3 weeks ago #169909 by Budrys
I installed that plugin but it's not shown in my joomla!
11 years 3 weeks ago #169913 by 810
mhh then is something wrong with your database or ftp permissions.
try to install this build:
www.jellekoksolutions.nl/pkg_kunena_v4.0.7-DEV2_2015-11-02.zip
Time to create page: 0.153 seconds
