Question White screen
11 years 4 months ago #166377 by shaney1466
White screen was created by shaney1466
Can somebody please help me, Kunena seems to have installed ok and is working in back end but front end just gives a white screen.
I get error report of:
Fatal error: Allowed memory size of 25165824 bytes exhausted (tried to allocate 105 bytes) in /home/sites/mywebsite.co.uk/public_html/libraries/joomla/language/language.php on line 804
My php.ini:
max_execution_time = 60
upload_max_filesize = 10M
post_max_size = 10M
memory_limit = 64M
display_errors = 0
register_globals = 0
output_buffering = 0
magic_quotes_gpc = '0'
Running:
Kunena 4.0.2 with no addons
Joomla 3.4.1
Database: 5.5.33
Template: tried my own and Beez3
11 years 4 months ago #166378 by rich
Replied by rich on topic White screen
Was the page sometime migrated? Go in backend to "Components > Redirect" and check if it's full with links.
11 years 4 months ago #166379 by shaney1466
Replied by shaney1466 on topic White screen
This is a new install and only has a few components, the redirect plugin was disabled but has made no change after i enabled it and there is nothing in components/redirect.
I am getting a new error report:
Fatal Error was detected!
The error was detected in the Kunena Component.
Fatal Error: Allowed memory size of 25165824 bytes exhausted (tried to allocate 122880 bytes) in components/com_kunena/template/blue_eagle/html/category/default_row.php on line 76
11 years 4 months ago - 11 years 4 months ago #166380 by sozzled
Replied by sozzled on topic White screen
I understand that you have installed K 4.0.2 and you have access to the backend Kunena component features. Is this correct?
I understand that, for some reason, when you try to use your frontend, you receive an out-of-memory fatal error . Is that right?
It may be an idea to show us your Kunena configuration report .
Your error message looks like your site obtains less than half the 64M your php.ini settings indicated: "Allowed memory size of 25165824 bytes exhausted."
Last edit: 11 years 4 months ago by sozzled.
11 years 4 months ago #166381 by shaney1466
Yes to both questions and here is my report...i have changed website address
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 24M | Max file upload: 10M
Joomla default template details : pcgeek004 | author: Shaney | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.2 | creationdate: 2015-06-26
Kunena version detailed: Kunena 4.0.2 | 2015-06-26 [ Corbolio ]
Plugins: None
11 years 4 months ago - 11 years 4 months ago #166383 by sozzled
Thanks. Your configuration report shows that the webhost policy allows a maximum of 24M for your site.
I understand that you attempted to override this setting in your php.ini.
Most shared webhosting providers do not allow individual customers to change the memory limit. The only real way out of this particular problem is ask your webhosting provider if they have (perhaps, in their top-of-the-line package) a solution that guarantees you the 64M you need. Alternatively, you may have to shop around for a different webhosting provider. Either solution, unfortunately, is going to cost you money.
The following user(s) said Thank You: shaney1466
