Question Update from 3.0.6 to 4.0 right away?
Can I update from 3.0.6 directly to 4.0 by installing 4.0 in Joomla manager?
Is there any special stuff I need to do. I can't find much information about the update from 3.0.6...or if I can skip previous versions...
I know I need to backup...but anything else?
Thank you for your answer.
- Chacapamac
- Junior Member
Any warning or special stuff to do before ?
In my case Joomla is still at 3.3.3 with Kunena 3.0.6
I saw that warning on your documentation ?
Not all versions of Kunena can be installed/upgraded on J! 3.4 websites. If you are upgrading from an older version of Kunena (that was previously installed on your Joomla website) on J! 3.4+ you can only use K 3.0.7 or higher
Should I update Joomla (3.4.1) first, Kunena (4.0.1) after ?
2) Update Joomla to J3.4.1
3) Update Kunena to K4.0.1
This means I cannot update to Kunena 4?
I can't update my site until my Joomlart template will provide me an update.. :pinch: oouch..
You can easy update.
Template should work.
