Question Does update process from kunena 3.x to 4.0.x remove data from tables?
10 years 11 months ago #165728 by joomlauser
Hello friends.
How to prevent losing data from kunena 3.x during update process into Kunena 4.x?
How to perform the update process without loosing data?
Is the database table structure of Kunena 4.x differ from Kunena 3.x?
Sometime ago I perform an update process of Kunena component by installing new version from Extension> Extension mamager> Upload & Install Joomla Extension.
What did I wrong?
Thank you in advance
Kind regards
10 years 11 months ago #165729 by 810
Just make sure you have a backup, in case its going wrong.
But it should not remove data. The structure is the same, but few new columns.
You can use the updater (updates to K4.0.0) , or download Kunena 4.0.1, and use the joomla installer.
10 years 11 months ago #165730 by sozzled
810 wrote: But it should not remove data. The structure is the same, but few new columns.
Is there a list somewhere of the new columns, please?
10 years 11 months ago #165731 by 810
10 years 11 months ago #165733 by sozzled
Thanks. If I understand correctly, the following image shows a list of the main database differences between K 3.0. and K 4.0:
There are one or two minor differences in terms of data content (mostly to fix up some of the "problems" people were having with the "new" indicator), but these are not game changers as far anyone should be too concerned about. Very useful information to have both as a user and as a developer. :)
10 years 11 months ago #165734 by joomlauser
810 wrote: Just make sure you have a backup, in case its going wrong.
My updater shows Kunena 3.0.8
My version is 3.0.6.
Should I firstly update from 3.0.6 to 3.0.8 or can I update directly to 4.0.1?
Time to create page: 0.269 seconds
