Kunena 6.4.13 Released
Solved Users cant see messages on next page
10 years 5 months ago - 10 years 5 months ago #173068 by pyrtsy
Hi.
After updating kunema to latest version from 3.xx i have this weird problem.
When user posts a message to thread and its first message on threads next page normal users cant see that page. However admin can see that next page and after admin replies to thread, page becomes visible to all.
Currently I am using joomla.level for access management but problem is same with groups.
Configuration report:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 100M
Joomla default template details : g5_hydrogen | author: RocketTheme, LLC | version: 5.2.10 | creationdate: February 8, 2016
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.10 | creationdate: 2016-02-18
Kunena version detailed: Kunena 4.0.10 | 2016-02-18 [ Villavicencio ]
Third-party components: UddeIM 3.8
Plugins: None
Last edit: 10 years 5 months ago by pyrtsy.
10 years 5 months ago #173069 by 810
try to disbale the kunena- Community Builder and kunena - jomsocial plugins, also disable Kunena - AlphaUserPoints plugin
10 years 5 months ago #173070 by pyrtsy
It seems that fixed it, thanks! At least with few test messages. Real use probably tells the real truth.
10 years 5 months ago #173098 by pyrtsy
Or not. Problem occurred also today.
It seems it affects only topics which existed before update. Database confliction or something?
I tried to look mysql database but I didn't find parameter which would be related to acl on specific messages. Category acl parameters seems to be fine.
10 years 5 months ago #173099 by pyrtsy
Well this is embarrassing. Everything is fine.
Thread has some deleted test messages which I ofc see when logged in as admin. So user sees less pages. :lol:
10 years 5 months ago - 10 years 5 months ago #173156 by pyrtsy
Argh. Problem indeed still occurs.
I checked my database. I noticed that in kunema_messages table some of messages have thread's first message as parent and some have previous message in thread as parent. Which should it be or does it matter?
However changing these values doesn't make effect.
Still the next page becomes visible to all after admin replies to that thread. You can even remove that message after that.
Time to create page: 0.284 seconds
