Solved Advertisment / banner between posts
10 years 11 months ago #171223 by Nikiniko
I searxhed first and i found this :
www.kunena.org/forum/k-3-0-general-templ...een-messages-of-post
That has a link to go here :
www.kunena.org/docs/Module_Positions
and with the use of ?tp=1 saws the positions.
Now if i want to ass a banner betwin posts the position is :
Position: kunena_msg_4 [ Style: xhtml outline]
kunena_msg_4
What about if i want to add a banner every 3 or 5 posts ?
How can i do it ?
10 years 11 months ago #171224 by rich
It depends on how many posts per page are displayed.
Example 9 posts:
Copy the module 2 x and use
original module to kunena_msg_3
copy 1 to kunena_msg_6
copy 2 to kunena_msg_9
The following user(s) said Thank You: Nikiniko
10 years 11 months ago - 10 years 11 months ago #171226 by Nikiniko
Example 20 posts for evey 5 posts
Copy the module 2 x and use >>>>>>>>>>>>>>> what is 2 x ? is it module's number? example 545 ?
original module to kunena_msg_0 >>>>>>>>>>>> is it before first post ?
copy 1 to kunena_msg_5
copy 2 to kunena_msg_10
copy 3 to kunena_msg_15
copy 4 to kunena_msg_20
And where i put all this ?
Last edit: 10 years 11 months ago by Nikiniko.
10 years 11 months ago #171244 by Nikiniko
Anyone ?
10 years 11 months ago #171250 by 810
you need to create a new module, for each option like kunena_msg_5.
then a new one for kunena_msg_10, kunena_msg_15 ect.
10 years 11 months ago #171254 by rich
Copy the created module as often as you need it.
kunena_msg_0 is not a module positiion. For advertising before first post use the position kunena_topictitle
Here is a video tutorial: How to Use the Joomla Custom Module
