Solved echo registerDate °Crypsis
10 years 11 months ago #170984 by breebee2
Woooow, this looks like it is it!!! Thank you thank you thank you thank you thank you!!!!!! :woohoo:
<ul> <?php if ($user->posts >= 1) : ?> <li> <?php echo JText::_('COM_KUNENA_POSTS') . ' ' . (int) $user->posts; ?> </li> <?php endif; ?> <?php if ($show && isset($user->thankyou)) : ?> <li> <?php echo JText::_('COM_KUNENA_MYPROFILE_THANKYOU_RECEIVED') . ' ' . (int) $user->thankyou; ?> </li> <?php endif; ?> <?php if ($show && !empty($points)) : ?> <li> <?php echo JText::_('COM_KUNENA_AUP_POINTS') . ' ' . $points; ?> </li> <?php endif; ?> <?php if ($show && !empty($medals)) : ?> <li> <?php echo implode(' ', $medals); ?> </li> <?php endif; ?> <li> <?php echo $user->profileIcon('gender'); ?> <?php echo $user->profileIcon('birthdate'); ?> <?php echo $user->profileIcon('location'); ?> <?php echo $user->profileIcon('website'); ?> <?php echo $user->profileIcon('private'); ?> <?php echo $user->profileIcon('email'); ?> </li> <?php echo $this->subLayout('Widget/Module')->set('position', 'kunena_topicprofilemore'); ?> </ul>
Time to create page: 0.097 seconds
