Solved echo registerDate °Crypsis
10 years 11 months ago #170951 by breebee2
I would like to echo the register date of the user in the crypsis template. Is there a simple way to insert this with the api registerDate? It would be a great feature to be able to spot trolls on the info site without having to jump to there profile to find out if they just subscribed. Thanks in advance, and thanks again for the uddeim hotfix i am very thankful.
10 years 11 months ago #170952 by 810
Replied by 810 on topic echo registerDate °Crypsis
$user->registerDate or $this->user->registerDate
should do the trick
The following user(s) said Thank You: breebee2
10 years 11 months ago #170954 by breebee2
Thanks! i will try and find where to insert this in the crypsis template for the threads if you are not sure which file i would need to edit. Your the best 810!
10 years 11 months ago - 10 years 11 months ago #170980 by breebee2
Im pretty lost actually.. /components/com_kunena/template/crypsis/media/js/topic.js atwho.js... pleasea hint to which file would really help :pinch:
Last edit: 10 years 11 months ago by breebee2.
10 years 11 months ago #170982 by 810
components/com_kunena/template/crypsis/layouts/user/profile/default.php
depends where you want the show up
10 years 11 months ago #170983 by breebee2
In the threads where people reply to each other. Im looking into the file now thanks! Im sorry to be such a burden really im trying my best not to ask for help
