Solved TImestamp problem
11 years 6 days ago #169570 by thomspl
TImestamp problem was created by thomspl
Hi I'm running 3.0.8 and the time that is shown is +15minutes to normal time. How can I fix this?
11 years 6 days ago #169575 by xillibit
Replied by xillibit on topic TImestamp problem
We are not supporting Kunena 3.0.x series since by end of august 2015, so i advise you to update to Kunena 4.0.6
11 years 6 days ago - 11 years 6 days ago #169577 by thomspl
Replied by thomspl on topic Time stamp problem
Ok I did update to 406 - still +15min on every timestamp
Last edit: 11 years 6 days ago by thomspl.
11 years 6 days ago #169578 by xillibit
Replied by xillibit on topic Time stamp problem
Kunena use datetime settings from Joomla!, so which settings do-you have set into Kunena configuration panel ?
11 years 6 days ago #169579 by thomspl
xillibit wrote: Kunena use datetime settings from Joomla!, so which settings do-you have set into Kunena configuration panel ?
sory, can you explain bit more? I don't have any config for time in kunena biside the format. J
11 years 6 days ago #169580 by xillibit
I would mean, can-you give please the settings of datetime in Joomla! configuration panel ?
