Kunena 7.0.8 Released
Solved Just updated the forum and now my text is light grey.
10 years 11 months ago #168988 by whatsupinthesky
This is most likely a simple fix. I just updated all of my Joomla updates for Kunena and it downloaded the new version.
When I logged back on all of the text that used to be black (In menu's and messages) is now a very light grey that my users are having trouble with. Is there anyway someone could help me. Is there a .css file I need to tinker with?
I am fairly new to this and everyones been enjoying the forum.
Thanks,
Will
www.whatsupinthesky.com
Forum page: whatsupinthesky.com/index.php/forum/index
10 years 11 months ago - 10 years 11 months ago #168989 by 810
for menu, you can change it on template settings.
For main color:
backend - template manager - select blue eagle - edit css - custom.css
Add:
#Kunena {
color: #000 !important;
Last edit: 10 years 11 months ago by 810.
10 years 11 months ago #168996 by whatsupinthesky
Wow you are fast! And did I mention rock!? Thank you so much! I would have spent all night messing with it!!
10 years 4 months ago #174562 by jplamp
I am having the same problem after upgrading from Kunena 2.0 to Kunena 4.0 on a Joomla 2.5 site.
But when I go to the Kunena template in the backend, I can't find any place to edit the .css for Blue Eagle. Is this no longer an option in 4.0? If not, how can I change the text color?
I can't even find the right .css file to edit. There is a CSS folder containing a lot of files, and I don't know which one to edit.
Thanks for any help you can give.
My configuration:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 800M | Max file upload: 300M
Joomla default template details : siteground-j16-47 | author: SiteGround | version: 2.5/3.0 | creationdate: 5 Jun 2012
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.10 | creationdate: 2016-02-18
Kunena version detailed: Kunena 4.0.10 | 2016-02-18 [ Villavicencio ]
Third-party components: CommunityBuilder 2.0.14 | UddeIM 3.2
Plugins: Search - Kunena Search 3.1.2 | Content - Kunena Discuss 2.0.4
Modules: Kunena Latest 3.1.2.1 | Kunena Stats 3.1.2 | Kunena Login 3.1.2 | Kunena Search 3.1.2
Kunena 4.0.11, Joomla 3.5.1, CB 2.0.14, DOCman 2.1.5, uddeIM 3.8
10 years 4 months ago #174576 by sozzled
jplamp wrote: When I go to the Kunena template in the backend, I can't find any place to edit the .css for Blue Eagle. Is this no longer an option in 4.0? If not, how can I change the text color?
Try
Template Manager » Blue Eagle » Edit CSS » custom.css
jplamp wrote: I can't even find the right .css file to edit. There is a CSS folder containing a lot of files, and I don't know which one to edit.
The most important thing is do not directly edit these CSS files!
If the information given above (and in msg #2 ) did not help, you might like to read the article What CSS file should I change …?
10 years 4 months ago #174588 by jplamp
The problem is that I see no place where it says "edit CSS". This is what I have when I choose Blue Eagle and click on "Edit" at the top of the page:
Time to create page: 0.381 seconds
