Solved Gavick Pro template: Kunena menu disappears on clicking Latest Post
12 years 11 months ago - 12 years 11 months ago #150870 by proterra
Have Kunena 3.03 and the Blue Eagle template and have the problem, if I click on latest Post in the overview and scroll up, the menu tabs not correctly visible.
This is my board (here I see the tabs):
www.scoteire.de/forum/aktuell.html
Here a last post (when you scroll to the top you didn´t see the tabs):
www.scoteire.de/forum/FORUM-SUPPORT/1365...html?start=10#142727
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 62500k | Max file upload: 10M
Joomla default template details : gk_music | author: GavickPro | version: 2.7 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: UddeIM 3.1
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
Last edit: 12 years 11 months ago by proterra.
12 years 11 months ago #150871 by Mortti
I think that our Rich can help you in your language... I can't see mistakes in www.scoteire.de/forum/FORUM-SUPPORT.html If you mean about screencast.com/t/vAgweUWk I think sozzled/Michael have posted several posts of this...
  • rich
  • rich's Avatar
  • Away
  • Kunena Moderator
  • Kunena Moderator
  • I like sunshine and flowers
12 years 11 months ago - 12 years 11 months ago #150896 by rich
@proterra
The error is caused by the Joomla template. Please try the following:
Search in your Joomla! template.css "templates/gk_music/css/template.css" the code #gkMain and disable the entry "overflow: hidden;". It should work.
Last edit: 12 years 11 months ago by rich.
12 years 11 months ago #150899 by 9themestore
I agree with you if remove the overflow of the #gkMain element it will work fine but have problem with some float elements. I suggest an other solution for this issue.
My solution: Open the layout.css file and go to about line 18, add the overflow property for the #gkMainBlock id.
#gkMainBlock { margin-bottom: 0 !important; overflow: hidden; /* Add this line */ }
I tried on firebug and it worked fine.
Regards,
  • rich
  • rich's Avatar
  • Away
  • Kunena Moderator
  • Kunena Moderator
12 years 11 months ago - 12 years 11 months ago #150901 by rich
Yes, you're right it's better. :)
12 years 11 months ago #150925 by proterra
Mortti wrote: If you mean about screencast.com/t/vAgweUWk I think sozzled/Michael have posted several posts of this...
Thats exact my problem.
Thanks for the help @9themestore and @rich, but these changes didn´t runs (have delete the cache etc)
Time to create page: 0.151 seconds
