Kunena 6.4.13 Released
Question forum statistics not showing
11 years 3 months ago #163458 by dk2015
Hi
I was using fireboard forum with joomla 1.5 version but now I migrated joomla 3.3.6 and also migrated kunena with migrated Joomla.Everything working fine but there is as issue overcome with
"forum statistics" ie not showing any thing under statistics section.
Here I have shared a screenshot for the reference.
Realy appreciate if help the same
Dhananjay
File Attachment:
File Name: screenshot.pdf
File Size:70.61 KB
11 years 3 months ago #163475 by rich
Replied by rich on topic forum statistics not showing
Go in backend to Kuena > Forum Tools and recount all statistks. Maybe it helps.
11 years 3 months ago #163491 by dk2015
Replied by dk2015 on topic forum statistics not showing
Hi Rich
I did the same but it remains as previous where as I worked with fresh latest Joomla 3.3.6.It shows everything in statistics section.
Please help
Dhananjay
11 years 3 months ago #163497 by rich
Please first upgrade your Joomla. Joomla 3.3.6 is obsolete. Currently is Joomla 3.4.1 up to date.
Then create a configuration report please.
www.kunena.org/docs/*_Commonly-asked_%28...estions_about_Kunena
11 years 3 months ago #163502 by dk2015
Can have a suggestion for kunena statistics section.can it not come with joomla 3.3.6 if do not want to upgrade 3.4. Please suggest.
I have posted the configuration report of my installed kunena.
Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : snmmaintemplate3 | author: Dhananjay singh | version: 3.1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.7 | creationdate: 2015-02-01
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Third-party components: CommunityBuilder 2.0.4
Third-party SEF components: sh404sef 4.2.1.1586
Plugins: None
Please review the same and suggest me.
11 years 3 months ago #163506 by 810
Replied by 810 on topic forum statistics not showing
check your settings on kunena plugins, you have selected everything on yes.
So i think there is a conflict now, disable all plugin that you don't use. and check the settings.
Time to create page: 0.338 seconds
