Merged Whole Joomla site crashed when doing an automated Kunena upgrade.
13 years 3 months ago - 13 years 3 months ago #144890 by stigbarrett
:angry:
In the upgrade process (which was started from inside Joomla), the screen became white. Now I can´t reach both front and back-end and the entire Joomla site (2.5.11.)
I have tried to copy fresh Joomla files over the site without any luck.
Any suggestion??
Last edit: 13 years 3 months ago by stigbarrett.
13 years 3 months ago #144895 by msrecycles
I had the same issue. Deleting the Kunena folders on the host using ftp (or cpanel) solved the issue for me to get the site back up; however, YMMV.
I am still searching through the forums to find a solution to the problem that has plagued me. While I haven't figured it out yet, my current thought is that I'm exceeding the SQL limit set by my host as I have been experiencing a lot more errors about the database not being found and/or exceeding resource limits.
13 years 3 months ago #144896 by xillibit
look in apache or php log if you can see an error related to that.
13 years 3 months ago #145490 by robertbseattle
I've had the same thing happen to me and I tested the installation on a local site as well.
Basically using the Joomla installation screen and as soon as it starts the page goes full white and nothing. Entire site crashed, front and back end. The only way out of it was to restore from backup.
Tried several times and gave up on Kenuna 3, using Kenuna 2 for now.
13 years 3 months ago #145496 by xillibit
try to diagnosize error 500 with that : www.kunena.org/docs/HTTP_500_Internal_Server_Error
13 years 2 months ago #146033 by fstltna
I am seeing this issue when i try to upgrade from kunena 2.x to 3.0.0/3.0.1. I tried uninstalling the whole existing 2.x installation but still get the white screen. Would posting my 2.x config help?
Time to create page: 0.276 seconds
