Kunena 6.4.13 Released
Sticky Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
13 years 2 months ago #144172 by webmaisterpro
naimless wrote: Hi Webmaisterpro - I'm having the same issue with a similar configuration (but no cloudflare) - did you manage to resolve it by any chance?
Unfortunately not, yesterday I tried again with all connections and related plugins disabled, same error occur and I was not able to trace it. However I saw something strange into my server logs. Installation was looking for .asp files which is very odd!
13 years 2 months ago #144173 by naimless
Fixed - appeared to be a JS conflict caused by (possibly an old version of) the Jomsocial javascript payload.
Disable the plugin 'Azrul System Mambot For Joomla', go to Kunena administration and the install should proceed. Re-enable the plugin after that and all should be dandy.
The following user(s) said Thank You: oumouy
13 years 2 months ago #144189 by oumouy
Hi when i tried to install Kunena 3.0,the installation proccess stopped and a message appeared telling me
Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation<\/td>\n\t\t \n\t\t.
your help will be so much appreciated
Ty in advance
13 years 2 months ago #144202 by xillibit
Try to look into \logs\kunena.php if you can see errors messages which can help.
13 years 2 months ago - 13 years 2 months ago #144211 by oumouy
Last edit: 13 years 2 months ago by oumouy.
Time to create page: 0.357 seconds
