Kunena 6.4.13 Released
Sticky Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
11 years 10 months ago #159569 by DaTOkz
deeman001 wrote:
810 wrote: contact me by Skype: jelle810
Thanks for your help Jelle. You fixed it by disabling all non standard joomla plugins before installing, then after it was installed successfully you re-enabled them. Works now.
Ok this work for install, thanks. :kiss:
11 years 10 months ago #159570 by deeman001
I found that the plugin that was causing the error turned out to be the "ECWID Single Sign-On Auth" plugin. when I disabled that one, Kunena was able to install.
I found an updated version of the "ECWID Single Sign-On Auth" plugin, and now I have no issues when I upgrade Kunena, so check your plugins from other developers to make sure they are up to date.
Time to create page: 0.240 seconds
