Kunena 6.4.13 Released
Sticky Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
12 years 2 months ago #156695 by deeman001
I am also getting this same error. I have tried disabling all plugins, and have uninstalled the previous version and then reinstalled, but it fails at this same point.
Forum is down, please help!!
12 years 2 months ago #156710 by deeman001
My Joomla System Cache plugin is disabled, and it's been turned off in the configuration file. Still not letting me complete the installation. My forum is down and I'm not sure what else to do.
Should I reinstall an older version?
12 years 2 months ago - 12 years 2 months ago #156716 by deeman001
810 wrote: contact me by Skype: jelle810
Thanks for your help Jelle. You fixed it by disabling all non standard joomla plugins before installing, then after it was installed successfully you re-enabled them. Works now.
Last edit: 12 years 2 months ago by deeman001.
11 years 10 months ago #159561 by DaTOkz
Hello all, im can install kunena in joomla 3.3.6, upload the package or install from url, is the same problem.
Kunena Installation Failed! Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation<\/td>\n\t\t \n\t\t... OK<\/td>\n\t\t <\/td>\n\t<\/tr>\n\t<\/table>\n"}
image:
im unistall and re-install is the same problem.
thanks. :(
Time to create page: 0.237 seconds
