Kunena 6.4.13 Released
Sticky Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
13 years 2 months ago #144223 by webmaisterpro
xillibit wrote: Hello,
Try to look into \logs\kunena.php if you can see errors messages which can help.
File is missing from my "logs" folder
13 years 2 months ago #144369 by Silentheal
Hi sorry for my english i'am french and have bad english :)
I tryed to make in 3.0 with joomla updade but install not work.
Look my error.
Désolé, l'installation a échoué avec l'erreur suivante:
{"success":true,"status":"33%","current":"Pr\u00e9paration de l'installation","log":"\n\t\n\t\t
Pr\u00e9paration de l'installation<\/td>\n\t\t \n\t\t... OK<\/td>\n\t\t <\/td>\n\t<\/tr>\n\t<\/table>\n"}
13 years 2 months ago #144787 by mindriot
{"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\tPrepare Installation<\/td>\n\t\t \n\t\t... OK<\/td>\n\t\t <\/td>\n\t<\/tr>\n\t<\/table>\n"
Argh, it broke almost immediately. First time Ive had a kunena fail in ages.
Any ideas?
Cant get the usual info output now to post.
latest joomla 2.5.11, php 5.3.10
13 years 2 months ago #144843 by xillibit
Do you have third party plugins installed ? You need to disable themen and retry the Kunena isntallation.
13 years 2 weeks ago #146578 by mediaguru
I had this problem too. Disabling the Azrul system mambot allowed the installation to property complete. Then of course I had to turn that mambot back on for Jomsocial to work.
12 years 9 months ago #150179 by 30402sw
My Kunena install failed with the following error:
Prepare Installation<\/td>\n\t\t \n\t\t... OK<\/td>\n\t\t <\/td>\n\t<\/tr>\n\t<\/table>\n"}
I am using Joomla 2.5.14. My site meets all current install requirements e.g. php etc.
Not sure what is going on here. I did see a previous post about uppercase database config but I checked the tables prefix and it is in lower case.
Time to create page: 0.249 seconds
