Solved Fatal error: Class 'KunenaForum' not found in ../administrator/components/com_kunena/install/model.php on line 1345
12 years 6 months ago - 12 years 6 months ago #150189 by Vova_OB
mysql 5.1.69-cll-lve
PHP Version 5.3.27
Joomla! 3.1.5 Stable
Kunena last release download today
Fatal error: Class 'KunenaForum' not found in /home/vovaob/samsklepav.com/test/administrator/components/com_kunena/install/model.php on line 1345
Last edit: 12 years 6 months ago by Vova_OB.
12 years 6 months ago #150190 by 810
Please uninstall kunena, then check if all files are deleted, in your ftp.
Then install again, looks like a not overwriten file.
Regards 810
The following user(s) said Thank You: Vova_OB
12 years 6 months ago #150191 by Vova_OB
I did it many time,uninstalling,clean old file at ftp, result:
ps please disable captcha for registered user at support forum
12 years 6 months ago #150192 by xillibit
Please check that the plugin System - Kunena is right enabled, if it disabled Kunena can't work correctly
12 years 6 months ago #150193 by Vova_OB
xillibit wrote: Hello,
Now , I install and enable kunena system plg, result:
12 years 6 months ago #150194 by Vova_OB
