- Thank you received: 3
Solved Kunena 3.0.3 upgrade (from 3.0.2)
- civilizationitalia
12 years 11 months ago #149667
by civilizationitalia
Kunena 3.0.3 upgrade (from 3.0.2) was created by civilizationitalia
I'm trying to install this version but I have problems: installation ends with a black "veil" that overlaps the page without the classical progress bar.
If I try to enter Kunena dashboard I have an "Installation in progress" page... But installation never completes.
Both applies to Google Chrome 30 and Mozilla Firefox 24.
12 years 11 months ago #149674
by 810
Replied by 810 on topic Kunena 3.0.3 upgrade (from 3.0.2)
Please try again. the updater wasn't overwrited.
And first clear cache
- spacecoast
12 years 11 months ago - 12 years 11 months ago #149681
by spacecoast
Replied by spacecoast on topic Kunena 3.0.3 upgrade (from 3.0.2)
I am having similar problems. No matter which way I try to update, it fails.
Nothing has changed on my site since the last update (whic I also had a problem with). Now I don't have access to the forum
The only thing I can think of is that it's something in my htaccess, I don't think so, but here it is anyway
#Use PHP 5.3
AddType application/x-httpd-php53 .php
## Can be commented out if causes errors, see notes above.
Options +FollowSymLinks
## Mod_rewrite in use.
RewriteEngine On
### Added
########## Begin - File execution order, by Komra.de
DirectoryIndex index.php index.html
########## End - File execution order
### Added
### Sitemap
RewriteCond %{REQUEST_URI} ^/sitemap.xml
RewriteRule .* /index.php?option=com_xmap&view=xml&id=1
### Sitemap End
### Added
########## Begin - Common hacking tools and bandwidth hoggers block
## By SigSiu.net and @nikosdion.
# This line also disables Akeeba Remote Control 2.5 and earlier
SetEnvIf user-agent "Indy Library" stayout=1
# WARNING: Disabling wget will also block the most common method for
# running CRON jobs. Remove if you have issues with CRON jobs.
# SetEnvIf user-agent "Wget" stayout=1
# The following rules are for bandwidth-hogging download tools
SetEnvIf user-agent "libwww-perl" stayout=1
SetEnvIf user-agent "Download Demon" stayout=1
SetEnvIf user-agent "GetRight" stayout=1
SetEnvIf user-agent "GetWeb!" stayout=1
SetEnvIf user-agent "Go!Zilla" stayout=1
SetEnvIf user-agent "Go-Ahead-Got-It" stayout=1
SetEnvIf user-agent "GrabNet" stayout=1
SetEnvIf user-agent "TurnitinBot" stayout=1
# This line denies access to all of the above tools
deny from env=stayout
########## End - Common hacking tools and bandwidth hoggers block
### Added
## Added
########## Begin - File injection protection, by SigSiu.net
RewriteCond %{REQUEST_METHOD} GET
RewriteCond %{QUERY_STRING} [a-zA-Z0-9_]=http:// [OR]
\.\.//?)+ [OR]
([a-z0-9_.]//?)+ [NC]
RewriteRule .* - [F]
########## End - File injection protection
## Added
## Begin - Rewrite rules to block out some common exploits.
# If you experience problems on your site block out the operations listed below
# This attempts to block the most common type of exploit `attempts` to Joomla!
# Block out any script trying to base64_encode data within the URL.
RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR]
# Block out any script that includes a <script> tag in URL.
RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL.
RewriteCond %{QUERY_STRING} GLOBALS(
\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL.
RewriteCond %{QUERY_STRING} _REQUEST(
\[|\%[0-9A-Z]{0,2})
# Return 403 Forbidden header and show the content of the root homepage
RewriteRule .* index.php [F]
RewriteCond %{HTTP_USER_AGENT} baidu [NC,OR]
RewriteCond %{HTTP_USER_AGENT} Sogou [OR]
RewriteCond %{HTTP_USER_AGENT} 80legs [OR]
RewriteCond %{HTTP_USER_AGENT} Inktomi
RewriteRule ^.* - [F,L]
## End - Rewrite rules to block out some common exploits.
## Begin - Custom redirects
# If you need to redirect some pages, or set a canonical non-www to
# www redirect (or vice versa), place that code here. Ensure those
# redirects use the correct RewriteRule syntax and the [R=301,L] flags.
## End - Custom redirects
# Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root).
# RewriteBase /
## Begin - Joomla! core SEF Section.
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# If the requested path and file is not /index.php and the request
# has not already been internally rewritten to the index.php script
RewriteCond %{REQUEST_URI} !^/index\.php
# and the request is for something within the component folder,
# or for the site root, or for an extensionless URL, or the
# requested URL ends with one of the listed extensions
RewriteCond %{REQUEST_URI} /component/|(/[^.]*|\.(php|html?|feed|pdf|vcf|raw))$ [NC]
# and the requested path and file doesn't directly match a physical file
RewriteCond %{REQUEST_FILENAME} !-f
# and the requested path and file doesn't directly match a physical folder
RewriteCond %{REQUEST_FILENAME} !-d
# internally rewrite the request to the index.php script
RewriteRule .* index.php [L]
## End - Joomla! core SEF Section.
#Use PHP 5.3
RewriteEngine On
### Added
### Added
### Sitemap
### Sitemap End
### Added
### Added
## Added
\.\.//?)+ [OR]RewriteCond %{QUERY_STRING} [a-zA-Z0-9_]
([a-z0-9_.]//?)+ [NC]RewriteRule .* - [F]
## Added
\[|\%[0-9A-Z]{0,2}) [OR]# Block out any script trying to modify a _REQUEST variable via URL.
\[|\%[0-9A-Z]{0,2})# Return 403 Forbidden header and show the content of the root homepage
# RewriteBase /
Last edit: 12 years 11 months ago by spacecoast.
12 years 11 months ago #149689
by 810
Can you check the php error log.
12 years 11 months ago #149696
by Matias
Replied by Matias on topic Kunena 3.0.3 upgrade (from 3.0.2)
You may be able to install 3.0.2 and get everything working again.
There are 2 sources that can cause installation process to fail like this. Either there's something wrong with the AJAX reply (some plugin adding extra content) or there's fatal error in PHP.
I doupt that its fatal error, but you should still check your Apache error logs just in case.
Can you check the network traffic (both Chrome and FF have tools that allows you to see all the requests) and check the replies for those requests. They should all be valid JSON.
- Thank you received: 165
12 years 11 months ago #149698
by Pinkeltje
Replied by Pinkeltje on topic Kunena 3.0.3 upgrade (from 3.0.2)
Not sure if it can help you, but I experienced similar problems when updating from 3.0.1 to 3.0.2. We use a modified version of the yag-solved plugin and the plugin had a check on Kunena version like this:
So respons was clear: DIE!
So may be you can disable all Kunena (related) plugins and try again.
// Do not load if Kunena version is not supported or Kunena is offline
if(!(class_exists('KunenaForum') && KunenaForum::isCompatible('2.0') && KunenaForum::installed()))
die;
Time to create page: 0.288 seconds
