Solved Installation error - Unable to create destination
13 years 2 months ago #147196 by Funesto
Hi .. I have a big problem installing Kunena.
My configuration is:
Joomla! Version Joomla! 3.1.5 Stable [ Ember ] 01-August-2013 14:00 GMT
PHP Version 5.3.3-7+squeeze14
Database Version 5.1.61-0+squeeze1
The Error I get is:
Unable to write entry
Warning
JFolder::create: Could not create directory Path: /home/mhd-01/www.ortonasondaggi.it/htdocs/components/com_kunena
Component Install: Failed to create site directory: /home/mhd-01/www.ortonasondaggi.it/htdocs/components/com_kunena
Package Install: There was an error installing an extension: com_kunena_v3.0.1.zip
Message
Error installing package
My permissions are: 777 and/or 755 .... everything is writable
Do you have an idea to help me, please?
Thanks!!
13 years 2 months ago #147198 by friday shoes
I've attached an image of the error I'm getting
I've check my file permissions are 777 and that my server meets/exceeds the minimum requirements
Any ideas how to resolve this?
13 years 2 months ago #147209 by Jiminimonka
Post details of your website, that screenshot is of no real help. You probably have some permissions issues on your server, but its not possible to assist you based on a screenshot.
Please read the FAQ.
Only one question per topic.
13 years 2 months ago #147210 by Jiminimonka
You should not have your folders set to 777 unless you want someone to hack your website. This issue is probably permission related, but you will have to post actual information for any support, like your URL for starters.
13 years 2 months ago - 13 years 2 months ago #147213 by friday shoes
Jiminimonka wrote: Post details of your website, that screenshot is of no real help. You probably have some permissions issues on your server, but its not possible to assist you based on a screenshot.
Here's some screen shots, if you can be more specific that would help, thanks
[img
[img
[img
If you need anymore, let me know. cheers
Last edit: 13 years 2 months ago by sozzled. Reason: Advertising links removed by moderator
13 years 2 months ago #147214 by Funesto
Replied by Funesto on topic Kunena 3.0.1 wont install
Thanks! I will bring permission back to 755 as I am back home from work. I installed other components without any jfolder issue...
I will give you more details this evening.... Thanks for trying helping me!!
