Kunena 7.0.8 Released
Solved Forum stuck in offline mode
13 years 2 weeks ago - 13 years 1 week ago #146775 by hydrox611
yes we moved hosting providers and now the forums wont come online they are stuck in offline mode. anybody have any ideas? I have attached the forum report config thanks.
Last edit: 13 years 1 week ago by hydrox611.
13 years 2 weeks ago #146785 by sozzled
Replied by sozzled on topic Forum stuck in offline mode
G'day, hydrox611, and welcome to Kunena.
There is probably a good reason why your forum remains "offline". Perhaps your forum is offline because the installation was not successful? Perhaps, if we saw your configuration report - which you did not include in your message to us - we may know more. :dry:
It is possible to change your forum from "offline" to "online" by changing the configuration setting or, in extreme cases, directly modify the value in the database.
13 years 1 week ago - 13 years 1 week ago #146835 by hydrox611
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : yoo_catalyst | author: YOOtheme | version: 1.0.7 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Search 3.0.1
13 years 1 week ago - 13 years 1 week ago #146847 by sozzled
Thank you for your reply. I have looked at your configuration report which shows "board_offline = 0" which means you should not be seeing the message "The forum is offline for maintenance". It seems as though there is something not quite right with the installation of Kunena on your website.
I noticed that you have another phpBB forum running on your site. Do you require two different forums?
As a suggestion, you can re-install K 3.0.1 on your site and, as long as you do not uninstall the K 3.0.1 you already have, you will not lose any forum data. You might like to try that. See K 3.0 Upgrade Guide for more help.
Last edit: 13 years 1 week ago by Jiminimonka. Reason: taking out [] extras around phpBB
13 years 1 week ago #146851 by hydrox611
Still same problem We put those up after we got this error and don't really want to use them as they are a pain in the butt. I am not sure what else I can do maybe uninstall it and clean up datebase of any files????
13 years 1 week ago #146853 by sozzled
Theoretically, if you DROP the table xxx_kunena_configuration and re-install Kunena then things should return to normal. Alternatively, try restoring your configuration to default settings.
This one has been beaten. :S
Time to create page: 0.263 seconds
