Please Read This First:
Do not use this category for:
Solved Kunena default template messing my site template
5 years 1 month ago - 5 years 1 month ago #218684 by [email protected]
If I use kunena a delivered template, it is messing up my site template. Like dis-orienting my headers by making the header bar big, and shrinking the page.. am I missing any setting here?
Last edit: 5 years 1 month ago by [email protected].
5 years 1 month ago #218689 by rich
I don't know, which bootstrap your Joomla template use.
Please add a configuration report:  docs.kunena.org/en/faq/configuration-report
5 years 1 month ago #218692 by [email protected]
thanks for quick reponse Rich. here is the configuration information
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 256M | Max file upload: 128M
Joomla default template details : shaper_helixultimate | author: JoomShaper.com | version: 1.1.4 | creationdate: Feb 2018
Kunena default template details : Aqidah Ku | author: JoomlaTema | version: 5.2.4 | creationdate: May 2021
Kunena template params:
Kunena version detailed: Kunena 5.2.6 | 2021-07-25 [ Melia ]
Plugins: None
5 years 1 month ago - 5 years 1 month ago #218694 by rich
Crypsis = bootstrap 2
Crypsisb3 = bootstrap 3
Crypsisb4 = bootstrap 4
Your Joomla template is written for bootstrap 4, so it will work only Crypsisb4.
Last edit: 5 years 1 month ago by rich.
5 years 1 month ago #218695 by [email protected]
Thank you so much. That helped. I unfortunately crypsisb4 does not look good on mysite. I wanted flat layout. Is there any other free template I can use. Any suggestions.
5 years 1 month ago #218696 by rich
You will have hardy to find such a template. I don't know 3rd party templates for free which working with currently Kunena versions.
Time to create page: 0.275 seconds
