Please Read This First:
Do not use this category for:
Solved Navigation Indicator seems off
9 years 4 months ago #193704 by Sugi123
Hi guys,
I am new to Joomla & kunena. I managed to installed kunena on localhost (Joomla 3.7), it was OK but Navigation Indicator (or what is called) seems off. See attachment.
How to correct that?
Thanks in advance,
Sugi
9 years 4 months ago #193712 by rich
Replied by rich on topic Navigation Indicator seems off
This will only take effect when you have minimum a second page.
9 years 4 months ago #194121 by Sugi123
I am sorry, not sure understood your answer.
Did you mean that if the page if more than 1, indicator's position will be normal?
9 years 4 months ago #194128 by rich
What you mean with "position will be normal"? You can't go to the next page, if you have only one page. Therefore is it inactive.
9 years 4 months ago #194132 by Sugi123
From the picture attached, the navigation buttons is not left alignment with other objects (combo box, Hello Members text, box for Breadcrumbs, etc)
I want to set this navigation buttons so it will left alignment with others objects.
9 years 4 months ago - 9 years 4 months ago #194134 by rich
I'm sorry, it was my mistake. I thought you mean the inactive "Next" button. Add this code in your custom.less . It's the second value. Probably you need more than 0px.
.layout#kunena .pagination { margin: 3px 0; }
Last edit: 9 years 4 months ago by rich.
